dougrainer
Sep 13, 2013Nomad
Most OEM's require the chassis engine running for slide out operation. The reason is simple, they want a FULL 12.8 to 13.2 volts available to operate the slide systems. Some OEM's, IF you have the Engine on or the key at Ign, the slides will not work---Newmar is one OEM that the slides will not work with the engine on. Doug
38,768 PostsLatest Activity: Nov 21, 2015
