Canadian_Rainbi
Sep 13, 2013Explorer
CA Traveler wrote:
When the mfg wants the engine running for slide operation consider:
1. Your neighbors if you want to move the slides at night and have to start the engine.
2. A DC motor will easily move the slide w/o the engine running so consider that the wiring is to small or the motor is to small or there is some other design constraint. Of course the higher voltage from the alternator can overcome some design constraints.
3. Slide motors draw little current, perhaps 20A and almost no power due to their short duration. So battery power is not a concern unless it's very discharged.
4. No one has mentioned operating the slides while on shore power. This implies that the charger does not maintain the chassis battery. If a solenoid is used to charge the house battery with the engine then there is very little cost to charging the chassis battery with the charger.
This is the case with many if not most motorhomes. We added a Xantrex Echo Charger to our rig which takes care of that problem, even under solar power.
38,768 PostsLatest Activity: Nov 21, 2015
