dougrainer
Sep 15, 2013Nomad
BarbaraOK wrote:dougrainer wrote:BarbaraOK wrote:
We also have slides that will not operate with the engine running. Nor will they go out until the jacks are down. So it isn't all or even most who need engines running. Sure sounds like bad design to have any thing to do with the house on chassis batteries. Sounds like manufacturers who skimped on designing number of house batteries to handle the load of all of the house functions.
Barb
Very FEW Motorhomes have the design that the jacks are to be extended before the slides operate. Me thinks you have an HWH system for both Jacks and slides as HWH DID offer that type design. But it was NOT standard for HWH jacks systems and only if you had Hydraulic slide system. The design of "which" battery system has nothing to do with shortcuts or cheapness by the OEM. It is just what the OEM and their Engineers decided to do. Some require the Engine running to make sure you have as MUCH battery power (Alternator) to power the system---usually Electric slide rooms. Some require the Engine OFF as a protection from the slide being able to extend in transit. There is NO set rule and their is no system that is "better" than others. My preference would be for the slides to operate anytime the engine is running. Which would mean BOTH battery banks would be online, so if one set was low the other and the engine Alternator would supply full power. Doug
Doug, are you in a gasser or DP?
Yes, we have an HWH system. Living room slide is very large so it make sense to use hydraulics for it. And since the system requires dumping air, then leveling, then the slide goes out, kind of hard to have the engine running and filling the air bags! While I know that Monaco requires slides out then dump air and leveling, most other DPs that use hydraulics are like ours.
And why is having sufficient batteries (we have 4-6 volt batteries) an anathema for RV Engineers - - except to save money? If our batteries are fully charged when we stop, we can level and extend slides without having to worry about our batteries and still have enough power to do everything we want until the next day when we start the generator to recharge if we are boondocking. And if we have FHUs then why would we need the engine running unless the inverter/converter couldn't recharge the batteries or can't keep up with the drain? If that is so, again it seems like a bad design. I do agree, people next to you wouldn't be happy if you have to start the engine just to bring in the slide in the middle of the night, which we've done before when the winds get real high (60 mph+) and we don't want the slide topper shredded.
Barb
No, I do NOT own an RV, I am a professional RV tech with 34 years experience working on motorhomes. We sold Alpine until they went under and NO, just having a Hyd slide system does not mean there is a standard procedure for leveling and deploying the slides and jacks. There is no harm done if you level the deploy or you deploy then level on fairly level ground. You do NOT want the chassis twisted and then try to extend the slide rooms. 1 battery fully charged will operate any electric slide room or hydraulic room. Doug
38,768 PostsLatest Activity: Nov 21, 2015
