StevenMarla wrote:
I called Thor and the service tech told me to look hard under the master bed. In some other wires is a red 6 gauge going to a two terminal little grey box. The copper wire terminal will have a reset button. The silver terminal will not. The problem is, I still can't find any of this he described.
Under my bed, on the passenger side, is a covered area. If I remove the cover, all the wiring is exposed. Near the front of this compartment is the battery disconnect relay and a wire from that runs back to an automotive circuit breaker, then to the battery. I don't remember the color, but maybe the "little grey box" is the circuit breaker. My circuit breaker went bad and I had to replace it. I can't send a photo because I redid all that wiring when I replaced my converter.
