ShotgunWriter wrote:
Malexander , do you think it could be the inverter, even though it appears to be working properly? (Charging the batteries, clicking on and off with power source change, breaker switches working?) I'm really hoping to not buy an inverter right now. My savings account has taken some pretty big hits this month.
If you've checked everything with a volt meter, (I had) and everything is checking normal, the inverter is really all that's left.
My 12v lights would sort of "fade" in and out. I should say my CONverter/charger was bad. It bench checked just fine, ie 120VAC in and 14VDC out. But when a load was applied, was when things would go south.
