Two_Hands's avatar
Two_Hands
House Water Pump Problem
The water pump keeps running after all faucets are turned off. The only way to turn it off is to turn off the pump switch. I just got the coach back from the shop where the technician did a leak test and the "system held pressure for 18 minutes at 70 psi. No leaks detected." Anyone have any ideas as to what might be wrong?
