Executive45
Jan 10, 2016Explorer III
You'll experience some traffic through El Paso, some wind, sometimes a lot, through New Mexico as you come into Lordsburg. There is a large pull just before Tucson. You'll undoubtedly will run into traffic coming through the Phoenix area even with using the bypass. Finally, you'll encounter a huge 15 mile downhill just before Indio. Since it's downhill you shouldn't have an overheating problem.
Here's my take..even though you didn't ask...I-10 is a pretty easy forgiving road coming east to west. That said, you're coming with a 'broken' coach. There are huge chunks of that road where there is nothing but tumbleweeds, lizards and the occasional buzzard. Is this someplace you want to be if your coach decides it's had enough:h:h. I'd get it fixed before I head out. I guarantee getting it fixed first will be less time consuming than if you break down in the middle of the desert and have to get towed and then get it fixed to get home. How lucky do you feel.:h:h:h......Dennis
