Tinstar
May 06, 2016Explorer
How are these things wired
First off, I know these won't work while plugged into a ground fault outlet AND it would only supply 60 amps total (as opposed to 100 amps for a regular 50 amp outlet. What I'm wondering is; how are they wired in the 50 amp side of the plug. Do they just run the 30 amp hot to one side, the other 30 amp hot to the other side then combine the two neutral wire and then combine the two ground wires.
Just FYI, I have access to two 30 amp RV outlets that are not wired to ground fault outlets at my home. I am wondering if I could use one of these to run both A/C units while at home.
