sailor_lou
Dec 07, 2013Explorer
Ivylog wrote:
I put a quarter under the battery boost switch to hold it on. Yes I know the Big Boy says "intermittent duty" but that's for 1200 amps, not 200 or less.
Are you sure? In electronics "intermittent duty" on a solenoid or relay usually refers to the coil not the contact ratings. Typically a solenoid or relay that is not rated to be continuously energized will overheat and burn out the coil wires. If the circuit was designed for continuous use the manufacturer would have installed a maintained contact switch. It's your rig, but I would be cautious about recommending a practice that defeats the normal operation or design of the system.
Lou
05 Travel Supreme Envoy
38,783 PostsLatest Activity: Sep 10, 2026
