skipnchar
May 16, 2013Explorer
It is easy to tell the difference with BOTH at hand to compare but individually, not so easy. EPDM is usually tighter when sliding an object across it while Vinyl does not drag as much when sliding the same object. If you can feel it easily dragging on your finger when you push it across it is likely Rubber.
38,763 PostsLatest Activity: Jul 22, 2018
