- twainharteartisExplorer
sailor_lou wrote:
twainharteartist wrote:
I pulled the fan and motor and there's the part number on the motor so I ordered one from RockAuto for a whole $27 delivered.
Glad you were able to easily find a replacement. Just out of curiosity, was it a Ford part?
Lou
05 Travel Supreme Envoy
Yes it was . It was for a Ford F53. - sailor_louExplorer
Lou
05 Travel Supreme Envoy - twainharteartisExplorerI pulled the fan and motor and there's the part number on the motor so I ordered one from RockAuto for a whole $27 delivered.
- wa8yxmExplorer IIIEasiest way is to pull into the lot at Auto-Zone, Discount Auto, O'Rilley's etc and remove the motor (if not already removed) to the parts's desk.
Tell 'em it is for a Ford and they will find it.. ODDS are very good they have one in stock and odds are it fits an F-350.. in fact likely an F=whatever.
Now I drive a Workhorse... That is how I did it. - sailor_louExplorerIf you are referring to the dash fan it could be almost anything. When the dash blower failed on our previous rig (97 Winne Vectra, F53, 460 CID w/ E4OD) I removed the motor and stopped at several Ford dealers looking for a replacement. Everyone gave me a blank stare and said they would need a part number. We were in SD at the time and then someone suggested I try NAPA. In New England the NAPA stores are pretty much as helpful as any of the large chain stores (ie: Autozone, Advance Autoparts, etc) so I thought it would be a wasted effort. However, I was pleasantly surprised to find a real parts store in SD setup for large machinery, most likely to support the farmers. The guy at the counter looked at the motor and in less than 5 seconds said it was a Chevy motor blower and handed me one within a few minutes.
Just because it's a Ford chassis doesn't mean too much when it comes to the coach parts installed by the MOHO manufacturer. Good luck.
Lou
05 Travel Supreme Envoy - fcooperExplorer IIWhen my dash blower motor failed, I just removed it and headed to the auto parts store. Took about 5 minutes for the guys behind the counter to find an exact match, and they had no listings for my motorhome. It will likely be a very common Ford item.
Fred - chuckftboyExplorerThere should be a tag on the evaporator cover that indicates a manufacturer and model number. Once you find that you could contact them for parts.
Or pull the motor and go to NAPA Auto Store and let them match it. Spec's should be on the motor itself. - twainharteartisExplorerIt is the Ford F450 I think. the motorhome is a 34 foot class A. Have a 460 Ford engine and the E40D trans.
- IvylogExplorer IIISince you included FORD I'll assume it's the dash AC so it's either a Ford Econoline or maybe a F350.
