JimMartin
Feb 23, 2014Explorer
Gjac wrote:
I believe it stands for emergency cut out. The thermal switch that Bud was referring to is inside a plastic tube and water from the relief valve drips on it and can become corroded at the connections. You can check this by removing it and jumper between the connections. If it lights and stays lit then replace the fuse if the connections are not corroded. Have you cleaned the thermo couple yet? Also I would clean all the connections fr the therm couple, ECO, thermostat,the control board, and the 3 ground wires. One is on the burner tube assy and the assy needs to be taken apart and cleaned to get a good ground. I assume this is an Atwood 6 gal WH?
Yes it's an Atwood 6 gal WH
38,768 PostsLatest Activity: Nov 21, 2015
