Tinstar
Aug 16, 2016Explorer
FIRE UP wrote:
Tinstar,
First off, let me ask you something. Before you go off and modify something, how many times has this happened to you? That is, does your generator stop, at the same EXACT FUEL TANK LEVEL, each and every time? Or, has this only done it one time. That is, how long have you owned the coach, used the generator, different fuel levels, and more? If this is the first time with this issue, I'd maybe, just for grins, fill it up, record everything, fuel level, generator hours, and run that coach 'till the tank level drops to what level you THINK the gen will quit at.
Then, you can do what you want, based on your test results. Or, just change what others have told you to change, your choice.
Scott
This was our maiden voyage Scott. I've had it for almost 3 months. I will probably not change anything unless it does it again and it quits at about the same fuel level. I'll go ahead and locate the supply and return lines. If it quits about the same level, maybe I can switch the lines around and see if it corrects. I'll be able to kill two birds with one stone. I can't see it doing anything different since I dipped the tank to check the fuel level and I tried to get it to run about 4 times after it quit and before I refilled. It gave me the same error "36" (low fuel level). BUT, it won't hurt anything to see what it does.
38,763 PostsLatest Activity: Dec 05, 2025
