Tinstar
Aug 17, 2016Explorer
dougrainer wrote:
You are confused about something. The Genset HAS NO WAY OF KNOWING YOUR FUEL SITUATION OR THE PICK UP TUBE LENGTH. That code is for when the Genset runs out of fuel. So, Onan assumes you have a fuel tank problem. There are NO sensors or any such wiring that tells the Genset that information. You can have a Fuel Pump problem. You can have ANY problem that is causing a lack fuel supply. Doug
No, I'm not confused. I just didn't write out the actually 36 code text. I just cut through the chase and wrote the bottom line.
38,763 PostsLatest Activity: Dec 05, 2025
