dougrainer
Aug 18, 2016Nomad
Tinstar wrote:dougrainer wrote:
You are confused. Your post states you have a Pick up tube problem. There is NO WAY a Genset or ANYTHING can tell you that. That code is ONAN for operational PROBLEMS with their Gensets. Doug
Well, I guess I am confused then. I read code 36 to indicate the genset was not getting fuel. It was my assumption that it was not getting fuel due to the fuel level being below the pick up tube for the genset inside the tank,,, especially when I fueled up and the genset worked again. What am I missing.
You jumped to the conclusion you have a fuel pick up tube problem. But, your unit is 13 years old? Have you always owned it or is it a recent purchase. The pick up tube on a Roadmaster is metal, so I will bet the feed and return lines are reversed at the Genset. Doug
38,763 PostsLatest Activity: Dec 05, 2025
