dougrainer
Aug 18, 2016Nomad
swapping the feed and return lines are easy. There are only 2 fuel lines at the rear bottom of the Genset. You just swap. No need to trace or go to the Fuel Pick up tube at the fuel tank. IF this was a problem from when it was built, do you really think the previous owners over 13 years would not have found this problem? And IF a problem, not corrected it? Odds are the Genset was worked on or the fuel lines at the Pick up tube were worked on and they reversed the hoses. Doug
38,763 PostsLatest Activity: Dec 05, 2025
