wolfe10
Jun 22, 2015Explorer
Not sure there is a "secret" to adjusting the A/C belt. If tension was proper before removing it to replace the serpentine belt, use a piece of tape above the adjustment area to mark where you want to return it.
With just moderate tension on the bolts securing the compressor, use whatever means you have to return it to its original position. I use water pump pliers. But, a couple of screwdrivers, bolts, etc in the adjustment area will allow you to pry it back to its proper position.
38,780 PostsLatest Activity: Aug 05, 2026
