rgatijnet1
Aug 13, 2016Explorer III
I used the standard adjustable shelving system that is available at most Home Depots and Lowes. If you look at them they have the side rails and brackets that go in to slots and then slide down a little to lock them in place. To keep them from popping out while on the road, all you need to do is put a sheet metal screw in the slot right above the bracket. This will prevent it from moving up in the rail and coming out. If you need to move the bracket, just remove the screw first.
