marc515's avatar
marc515
How do you guys stabilize your RV's in the campground?
For those of you who don't have built in levelers, how do you stabilize/keep your RV's from swaying while parked in campgrounds?
Appreciate any insight you can provide.
Thank you,
m
  • IAMICHABOD wrote:
    While like the others I don't stabilize my RV,just level it,it doesn't move much.
    However while camping next to a rather Robust couple I saw that they used These placed under all 4 corners of the house part to keep it from rocking.
    We used 2 of those at the rear frame corners just to take out the bit of bounce as our large dogs moved around at night. Worked great, and they're a cheap and compact solution
  • While like the others I don't stabilize my RV,just level it,it doesn't move much.
  • For leveling, I have a series of 2x ramps that I use as needed.
    For stabilization, I haven't found I need to do anything special. There's not enough rocking in my RV to annoy me. Maybe that's not an answer you were looking for, but it's the only one I can give.
  • We don't stabilize, but we do level the rig. Most often, for us, just being level is good enough for our 27 foot Class C.
  • JT Strongarm stabilizers. You might want to search this forum for `stabilize' to read previous posts. Lots of info.
    To minimize the results search only in the Class C category.
  • My fiver is 36 feet long. In order to help stabilize it, I first replaced the 10ga steel box the rear stabilizers were bolted to with more substantial pads. Then I added a second set of stabilizers just ahead of the axles. That took probsbly 90% of the movement out, and cost a lot less that JT strong arms.
