ron_dittmer
Apr 25, 2016Explorer III
When installing those little stick-on levels, make sure to first level the floor of the motor home in all directions using a calibrated level. A calibrated level will measure the exact same when rotated 180 degrees. With the RV house floor level, stick on your little levels "level".
As I mentioned before, I place a level front-to-back and side-to-side by the driver. I also have one placed outside in back and just forward of each rear tire. It helps to see right at the rear tires, how many blocks to stack up. I really should also stick a level by each front tire.
