dougrainer
May 09, 2015Nomad
draboo wrote:
Thanks for the replies! I m officially confused now. :) So..let me revise the question once again:
I would like, sometime in the near future, take out all the batteries(2 chassis/3 house batteries) and repair the warped floor of the battery compartment. This may take a half a day or so. We will be parked, plugged in(hopefully to a 50A service) and living in the MH whilst I do the repair. Will I have any trouble with the shore power powering the 12V needs (like furnace!) without the batteries hooked up?
Holiday Rambler 2002 34ft diesel Neptune with a Freedom Combi model 15 (1500 watt) converter.
Sorry for the confusion!
Yes, You have the Freedom combi (means Inverter/CHARGER). That means you HAVE to have a battery connected to allow the Freedom to do its job. Just leave a 12 volt battery on the ground and run 2 short battery cables to the ground and positive cable for the Inverter/Charger. OR, if you are positive it will take less than 1 day to do your repair, just shut down the RV for that amount of time. Doug
38,782 PostsLatest Activity: Aug 31, 2026
