ILVMYGT
Aug 17, 2015Explorer
If you plan on doing this for all future oil changes you might consider installing a valve in the drain plus. I bought one with a nipple so I can run a hose to the waste container. I drain 5 gallons out then switch containers. My CAT takes 9 gallons. That has made changing the oil a lot easier over the years. I bought one from Fumoto
https://fumotodirect.com
38,706 PostsLatest Activity: Jan 20, 2025
