rk911
Jul 22, 2013Explorer
MacGyver612 wrote:
The antenna coax is cracked at the outside on the motorhome we just bought. 2002 Itasca Suncruiser. How hard is it to replace and what kind works best?
Winegard crank up type.
Thanx
Greg
on our 2000 suncreuiser there is a connector on the roof. you'll need about a 6-8 foot run (measure the old coax before buying the new) of RG-6 coax (75-ohm) with connectors on both ends. if your roof is like mine you'll need to peel away the silicone protectorant off of the roof connector and possibly the connector at the antenna end. unscrew the cable connectors from the roof and antenna, replace with the new cable and seal with silicone.
38,766 PostsLatest Activity: Jan 10, 2026
