rk911
Jul 22, 2013Explorer
PastorCharlie wrote:
If it is only the outside rubber weather cover on the cable cracked cover the cable's bad area with Dicor caulk and that will reseal it. The cable has a wire shield that will prevent the cable from actually breaking into and protect it from signal interference.
yahbut the crack in the outer covering will let moisture in and if the crack has been there for any length of time the coax may have been saturated with water. cable is cheap so if at all possible i'd replace that section.
38,766 PostsLatest Activity: Jan 10, 2026
