tropical36
Dec 22, 2016Explorer II
lacofdfireman wrote:
We have a 07 Georgetown 350DS SE Bunk model class A. We are having a blast with this motorhome but our Generator hours are getting out of control. We have put almost 500hrs on our generator this year and our biggest reason was for watching TV as we travel down the road. Kids enjoy laying on the bed in the back room and watching TV shows etc while we travel. Just wondering if there is a better more efficiant way to do this and I'm sure an inverter has to be the way to go. We have currently 2 Trojan T105 6V batteries running our coach. All our TV's are LCD's so don't think they would drain the batteries to fast. How can I go about this? Is it going to be a major deal to make this work or is it possible without having to tear into walls etc. I have no idea how I'd run power down to my batteries for the inverter. Is there any special way without to much demolition? I'd like to do this myself. Also what type of inverter and power do I need. And how can I hook it up so it runs all the tv's?
The easiest way is to pick a compartment very near the house batteries (do no mount it in the battery compartment) and run min. #2awg wiring to a 1100watt modified sine wave inverter from the batteries, like this one....
INVERTER
Then run #12awg romex or armored cable from the inverter's 120vac outlets to your shore power compartment. Just be sure to shut off all heavy power breakers before plugging the inverter in to your shore cord. This will take some adapters that you should have on board anyway.
Even though, you should be watching what you're doing, by using this method, so you won't trip the inverter or suck your batteries dry, you save a lot of work with running dedicated outlets here and there and can easily run anything you want and where you want within reason, by doing nothing else. For instance you can run the fridge while going down the road and with a residential unit, probably all night long after an evening of TV.
With whatever outlets you might leave powered up (ac's must be off), use good common sense and don't be plugging hair dryers and the like into them. having said that, people have made a pot of coffee in the morning and got by with it. Once you're done though, you're done and have pretty much depleted your batteries. Alternator should charge them back up going down the road, but still not a good practice. Now once you're moving, you could actually do a lot, including putting the slow cooker on for dinner, by securing such in the sink.
As for just watching TV in the back, you might get by with just plugging in a 150watt inverter into the nearest 12vdc outlet. Many don't have much luck with these though, as they tend to put long runs of small gauge wire to feed these things. Only way to really know, is to try it.
Whatever you decide, I certainly wouldn't be running a big genset, just to power up small appliances, like a TV.
38,782 PostsLatest Activity: Sep 02, 2026
