DaHose
Aug 17, 2013Explorer
You had the right idea. If you only welded the top surface and aren't absolutely positive about full penetration of your weld, then you need to keep a close eye on it. It could rupture when full and traveling home.
The best way to repair that kind of damage is with a plastic welding kit. A large repair like that tank might work best with the kind that is like a modified heat gun. I have the kind of welder that looks like a giant, really hot soldering iron.
The actual repair would involve grinding the crack into a V so you can get full penetration. Then fill the bead. Finish by welding a strip of steel mesh onto the whole length of the crack and cover with a thick/wide layer of abs to make a super solid weld. I would trust that process to make a weld that lasts the life of the coach.
Jose
Jose
38,768 PostsLatest Activity: Jan 26, 2021
