texnwar
Aug 08, 2017Explorer
Please help - Black water holding tank damaged
The fitting itself snapped off with a section of the fiberglass black water tank. Is it possible to do a fiberglass repair and add a new fitting to it? I can't remove the tank as it's above the frame of the trailer. Any suggestions would be great as I am not sure how to go about fixing this. Thanks. See pics included.
Edit: Not sure why I can't post links to images and why embedded pics won't display here :/
To post a photo on the forums,
Click here.
To use it you:
1. Upload your picture to the app.
2. Copy/paste the resulting URL into a post. Do not make ANY changes to the URl. Don't add anything and don't take anything out.
3. You are done. The photo will appear and be properly sized for use here on our forums.
Take a look at my post announcing the app here. That should help you out a bit
Barney
Moderator edit to fix picture links.
Click here.
To use it you:
Barney
