wa8yxm
Mar 30, 2019Explorer III
PastorCharlie wrote:
As long as it works proper do not fix it.
The thermistor itself is vital without it the control system has no clue as to how hot or cold it is in there so it will either keep cooling till everything is froze solid... or shut down and nothing gets cold..
However as the Pastor said. If its working.. Don't fix it. You might want to "Attach" it to the current location somehow.. I suggest a glue on "eye" with a zip tie to hold it. (nothing that cuts or covers) or a peal and stick eye (like you'd stick the zip tie through) and stick the sensor into the eye if it's the right size. Just as long as you do not tear it out removing the shelf.
38,771 PostsLatest Activity: Apr 13, 2026
