dougrainer
Aug 21, 2015Nomad
harold1946 wrote:
Sitting next to us now is a 2005 30 ft. Airstream Land yacht MH that is 30 amp with 2 AC units and both are running at the same time. They say they bought it new.
It has an EMS system that allows both AC's to run on 30 amp service. When you go over the 30 amp threshold, the rear AC drops out until the amp draw falls back to allow both AC's to run. Also, it may be a load shed EMS system that ONLY kicks out the rear AC compressor and allows the Fan to run to help circulate cold air thruout. Can you tell if it has RVP(Coleman) AC units or Dometic? A/S usually used Dometic. But, RVP has a line of LOW amp Roof AC units designed for 30 amp service RV's that only pull about 9 to 11 amps EACH. Doug
