- T18skyguyExplorer
Super_Dave wrote:
What no one is acknowledging is you spend the time to type a long thought out reply and the system crashes when you hit the submit button. Sure, if you are just reading, refresh is just a small annoyance.
I hear ya. I've starting copying all my replies, so if it crashes, I can go back in and paste it. I appreciate how hard everybody works on the system, but I've lost a lot of confidence in it. - garmpExplorer III switched to using Trailer Life and even that's a bit doggy at times.
- 6door74Explorer
If you hit refresh it will reload and post like normal. I've done that and it has worked. didn't result in a double post either. just don't hit the back arrow or anything else. As mentioned, copy it too so you can paste if it's a long one - CharlesinGAExplorerI always get the same error message, from a server in Jakarta, Indonesia, so I am now careful to copy posts before I hit the send key, in case it does not go thru, I don't have to retype it.
Well, just did it trying to send this........
Got this message, same as always.
Service Temporarily Unavailable!
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Jakarta/ISAPI/isapi_redirector/1.2.40
Usually this kind of thing happens when an undersea cable gets damaged and traffic gets re-routed and things overload, such as a couple of years ago when a ship dropped an anchor on a cable in the eastern Mediterranean near Egypt. I have not heard of anything lately like this...........
Charles - p220sigmanExplorer
I have always copied a long reply before hitting submit just in case. That way, if it doesn't go through for some reason, I just paste it back in a new window and submit again. Short replies like this one, I would just retype if necessary. - opnspacesNavigator III@ Superdave,
I used to run into that issue many times, though now it's a bit better.
But since it bit me a few tim4es I try to remember to highlight all the text and do a copy (CTRL-C on Windows) before I click on post. That way if the forum crashes I can just start a new post and paste (CTRL-V) the text back in. - navegatorExplorerDon't you miss the telex machine, type everything on the tape and then send the message after it was punched and ran the tape on the send mode?
And yes I also navigated using Loran.
navegator - Super_DaveExplorer IIWhat no one is acknowledging is you spend the time to type a long thought out reply and the system crashes when you hit the submit button. Sure, if you are just reading, refresh is just a small annoyance.
- navegatorExplorerI have this same mesage from other sites not just RV NET but from comercial sites as well, it seems that the internet usage has a lot to do with this, late at night the area of Canada, USA, Mexico and Latin America when everyone is asleep this does not happen, in contrast some European sites seem to have the same problem as they start to steer in the morning, I just press the return icon and try again, some times several times.
So try and then try again and then try one more time.
navegator - p220sigmanExplorerIf i click on a link and it doesn't immediately load (I usually have a very fast connection), I just click again. It rarely takes more than 2 clicks and I avoid the error message.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 18, 2026
