Griff_in_Fairba
May 02, 2008Explorer
Tzvi wrote:
On a Dodge Delta 1977, I've got Carburator problem, my Mechanic says it might have a damaged float and Idle circuit is not functioning properly. The Vin is F44cF7V which I think translates as 10,001-14,000 Gwvr, 360 2 BBL (carb), 1977. It could be the PO put on a damaged and not proper fitting Carburator. I also have a plate that says: GVWR-10,500 Del-M-1542 Sierra Vista Chevy Dodge Model 100-400. Where would I get a replacement that would fit? Leeann, I hope you can help me with this, Thanks, how about anyone else out there?
Thank you. Tzvi
That would be a Carter BBD carburetor. Rebuilt replacements are readily avaiiable. ($260 at NAPA Online ... you may be able to get a better price elsewhere.) Have the counter people look up the carburetor for a 1977 B-300 Van with a 360 engine.
Kits to rebuild the carburetor yourself are also readily available for $40-60. I've rebuilt Carter BBD's multiple times, especially on my 1977 B-200 with 318 engine. (Too much Heet, used too often, kept eating up the carburetor seals.)
Personally, I'd seriously consider spending some extra money and switch to an Edelbrock Performer intake manifold and Performer carburetor. It should improve your gas mileage slightly, assuming you can stay out of the secondaries. Likewise, it should be more reliable than the Carter BBD.
38,708 PostsLatest Activity: Mar 05, 2025
