ellenjackson
Feb 16, 2025Explorer
You're right—new engines can be shockingly expensive! The Cummins ISX15 engine, depending on the specs, can cost anywhere from $40,000 to $75,000 brand new from an OEM dealer. Other models like the ISX12 or ISB6.7 tend to be a bit cheaper, but they’re still a hefty investment. A lot of fleets and companies that use Earth Movers Equipment opt for rebuilt or remanufactured engines to cut costs. If you're just curious, checking with a Cummins dealer or a heavy equipment supplier might give you the most accurate pricing.
StirCrazy
Feb 17, 2025Moderator
aside from this post being 10 years old, national truck parts sells then for about 25k, they say new but I suspect it is just a used in good condition.
