Spizzer's avatar
Spizzer
How much rust is normal?
Looked seriously at a 2007 coach today. One thing upon inspection is some rust. Inside a couple of the cargo storage doors, the bottom corners had some peeling paint and rust, not bigger than a half dollar or so. I looked all underneath and the chassis and other parts are rust free, but strangely some bolted on piece might be rusted. On the very bottom of a tank, behind the fuel tank ( not sure what it is) had a bit of rust on the seams.
The coach has had some months during the winter in Georgia, but otherwise stored in a dry climate. It seems a bit of sanding and rustoleum might clean it up. On another one in Colorado I looked at (same coach, same miles) it was absolutely clean. Colorado is pretty dry, though.
So, how much rust is something to really worry about?
Thanks,
Jeff
  • It is close to impossible to avoid corrosion in places with a humid climate. For vehicles in such places, Steel is galvanized by covering it with a zinc coating only a few thousandths of an inch thick. The automobile industry now uses a zinc coating on body panels to prevent rust on vehicles. Check whether your vehicle has this covering on it. For other stainless steel appliances, I use Innoprotect B580. This forms a protective layer on the metal and prevents it from corrosion.
    Check whether the following link can help you
    Prevent Corrosion of Metals
  • hotbyte wrote:
    I'm in Georgia and no rust on our 2006.
    I lived in Georgia for 3 years and the humidity there was pretty high, Do you do anything to keep it at at bay?
    jeff
  • marbilupton wrote:
    I just finished derusting and painting with Rustoleum my cargo doors and battery compartment on my 2005.
    It won't take much to get this cleaned up I guess, just concerned me that it might be an issue.
    jeff
  • TimReeves wrote:
    Hey I meant treatment of rust should be done at the earlier stage not waiting for it to spread and cause more damage.
    I understand! I grew up in Upper Michigan when they salted the roads, I have seen what rust can do!!!
    jeff
  • SCVJeff wrote:
    Are we talking about the same Journey in the other post?
    It's common in the places you are talking about, and just lousy prep at the factory. A PITA, but easily fixed.
    This is the same Journey as in the other post. I think the rust is not a big issue, the rest of the coach is in really good condition.
    jeff
  • Hey I meant treatment of rust should be done at the earlier stage not waiting for it to spread and cause more damage.
  • Are we talking about the same Journey in the other post?
  • Rust never stops. It is best to prevent metals from rusting. If at all you find a few signs of rust, it is better to clear the problem before it becomes more adverse. There is no limit to rust and so it is not advisable to avoid even an inch of rust.
  • I just finished derusting and painting with Rustoleum my cargo doors and battery compartment on my 2005.
