- garyhauptExplorerManufacturer shop prices. That just sucks. I see that your state has a fairly active consumer complaint office. You might consider launching a formal compliant with them.
Gary Haupt - StarkNakedExplorer IIO.K. Brace yourselves....
$1522.00 including tax.
And yes, they did refill the gas.
And someone screwed with the bike rack. Too dark to tell how much damage... - j-dExplorer III might be able to figure a way to do it were the coach on my pad at home. Out on a trip? YIKES!
Paul, I've thought of pre-emptive action. Drop Tank, Remove Pump. Replace Pump with Tubing, maybe even a Gutted Pump. Then install an In-Line Pump close to the Tank.
A few OP's here have done something like that with the older carbureted E350's. It's easier because the old low-pressure pumps allow fuel to be pulled through them when not running. The problem seemed to be that the new pumps just didn't last very long. I suppose the pump could be installed with roadside replacement in mind... - garyhauptExplorer
StarkNaked wrote:
Thanks for all the reply's.
And to answer the question of how much gas is in the tank..... We've only driven about 50 miles since a full tank top off...
Does that all get dumped? Or will they put it back in?
Thanks again!
They put it all back. They'll just drain it out out into 5 gallon type plastic fuel jugs, then pour it back in.
Gary Haupt - BILDERExplorerreplaced mine on the floor with half of a tank in 5 1/2 hours
no lift, did not drain the tank just used two floor jacks
f250 4x4 gas - PaulJ2Explorer
j-d wrote:
Rock, I'm sure they put 'em in the tank for Cost and Ease of (factory) Assembly. But there IS a practical advantage. An in-tank WILL pressurize the full fuel system RIGHT NOW once you turn the Key On. Also, there's a practical advantage: Much less tendency for gasoline under Pressure to Vapor Lock than when under Suction.
Pump could be mounted to the outside of the tank and still have a fully pressorized system. So I believe it is a cost and ease of assembly thing at the factory. - rockhillmanorExplorer IIThat came up with mine too I had a full tank. Can't really remember the details but I think it had to do with a tank big enough to hold the gas and epa laws.
I just told them to give it to the repair guys in the shop and they gave me a discount on the repair bill. Everyone was happy. - bukhrnNomad
StarkNaked wrote:
If it was mine, they damned well BETTER put it back in, unless they can prove to me that it somehow was contaminated,( I don't know how it would be) if they spill it, dump it or do anything else with it, THEY should pay to fill it.
Thanks again! - ValkyriebushExplorer II$900.00 on my previous RV 11 years ago! F-53 chassis.
- StarkNakedExplorer IIThanks for all the reply's.
Thanks again!
38,773 PostsLatest Activity: Apr 24, 2026
