wildtoad
Aug 11, 2018Explorer II
The easy way is get the weight of the equinox and compare it to the GCWR minus the GVWR (This difference should already be printed somewhere). If the equinox is higher don’t get it. If it is lower then you’re fine. I bet you can get the equinox. You can get the mh weighed if you want to but I doubt in this case that you need to.
38,768 PostsLatest Activity: Dec 18, 2017
