jplante4
Aug 11, 2018Explorer II
There's a fix for the wobble on the Equinox. I've only had it once and once you understand where it happens, you can avoid it. The best way to avoid it is to supply 12v charging to the toad so you don't have to pull any fuses.
Chevy has acknowledged the issue and has issued a change in the fuse to pull from fuse 32 next to the pax seat to fuse 16 under the hood. This thread outlines what needs to be done.
38,768 PostsLatest Activity: Dec 18, 2017
