wa8yxm
Aug 11, 2018Explorer III
There are two or 3 limits on your towing..
First is the rating of the hitch. NOTE that this rating only applies if the tow is truly flat That means....
Receiver---Tow bars----Base plate on towed
If you use a drop or rise adapter so it is like this
Receiver|
. . . . |Drop receiver==Tow bars==Base plate as above
Then the hitch is subjected to torque load and seriously less capable (Tore mine right off the RV with a 4,000 towed)
Next we have the MAX CGVW of the RV. say 26,000 pounds (I'm using mine)
Less the scaled weight of the RV (22,000 pounds in my case)
26,000=22,000 Well that's the 4,000 pound towed I used to have
new towed is 2500 pounds.
Receiver|
38,769 PostsLatest Activity: Mar 28, 2026
