Sir_Traveller's avatar
Feb 05, 2021
How often to disconnect from shore power
Hello Everyone…
I have a 2003 Ford F-53 RV
I have questions regarding charging house & chassis batteries, How often to disconnect from shore power
I usually stay hooked up to shore power for 6 months, then leave the RV in storage for the other 6 months … So after 3 years of this schedule the chassis battery died even though I was hooked up for months , and now the deep cycle batteries are leaking .. (I did replace the starting battery )
What are my options in this case to increase the longevity of both the starting and house batteries? (Since the charging system is built in) disconnect from the shore power for few minutes every day? For few hours every week? Should I remove the negative terminal from the starting battery even when hooked to shore power? If so then how often?
Take into consideration that my fridge and microwave work only when connected to shore power… I do not know much about how electric systems work so that is why I ask all these details to make sure I get it right
