wannavolunteerF's avatar
Apr 27, 2014
How Old to Buy?
Looking to buy a Used GAS class A to fulltime in. I plan to fulltime at least 10 years and possibly as long as 15, before I settle down in some "retirement" type setting. How old of a MH should I consider, knowing I will be traveling some and sitting some for a number of years? My income will not allow me to spend 100K on the MH, as I will need toad and a bit for emergencies, but am a bit flexible, as I will be selling TT and F150 to offset part of purchase price. I am slightly handy, but will have someone do major maintenance and repairs. I don't do ladders, so will have all roof work done too.
  • JimM68 wrote:
    Coincidentally, Ford came out with the V10 engine in 1999, and also widened the frontend track considerably. You can spot older ones from across the parking lot, a '98 460 coach the front tires are so far inside the wheelwells it looks like, well u know, like the front tires are so far inside the wheelwells.
    the same is true for the chevy P-30/32 chassis. front tires are recessed on the older ones.
    but be sure of the age of the chassis, not the motorhome as some manufacturer's had the old chassis and put them under three year newer motorhomes.
    bumpy
    Are you financing the difference? On any coach older than 10 years, bank loans are harder to find than Bigfoot.
    If paying cash, I'd look for a premium-quality coach if going older than 10 years.
    I bought a 10yr-old motorhome. I financed it and it took forever to pay off (Live and Learn...its now cash or tent-camping). The motorhome is now 21 years old, but requires constant preventative maintenance to keep it going. Its only saving grace: Its a Diesel.
    If I had purchased a 15-yr-old premium coach for the same money (Foretravel), I would have saved a lot of money over the years. Yeah, they are pricey but aren't as needy.
  • Without a budget this is tough...
    IMHO slideouts are good. More slideouts are always better than less. Slides began in 1999ish and were very common by 2001.
    The early V10's had a 4 speed trans that didn't have tow/haul. So if you see a tow haul switch, it is a 5 speed trans, teamed with the new 362hp 3 valve V10.
    PLAN on a TOAD. Anything. An old Saturn. a Jeep. almost any 4x4 or manual trans front wheel drive car (do your homework here) but get something to drive around while your home is "Home"
  • I have a 92 Winnie..had it for 10 years. I now find it hard to get parts.. If you are going to keep your coach for 10 years or more, I would think not more than 5 years old on the purchase.
  • I am slightly handy, but will have someone do major maintenance and repairs. I don't do ladders,I don't do ladders, so will have all roof work done too.
    Look for MH 5-10 years old with a fiberglass roof like Winnebago or Tiffin. 2nd choice a 2005 or newer Newmar with a BritTEK roof
  • If I were to start full timing, I would sell my MH and buy a truck and a 5er. Since you already have the truck, buy a bigger trailer if the truck you have currently is sufficient to tow something larger. If it is not, low mileage pick ups are readily available out there that can tow something larger. JMHO
  • if a ford, make it a 1999 or newer chassis with the 19 inch wheels. if chevy, avoid the old P-30/32 chassis which was rebranded as a workhorse.
    2005 and newer should be safe.
    bumpy
  • I would look in the mid 2000's for a gas coach since most made after 2004 will have decent engines and newer systems in the coach. Both the Ford and GM engined coaches from the mid 2000's should go 200,000 miles with normal maintenance and they are new enough that parts are available at most auto parts stores. Some of the GM powered coaches have an Allison transmission which is known to last a long time with minimal maintenance. Try to find a low mileage coach that was not used by a full-timer. This would have lower hours on the systems and less wear on the furnishings. If the electronics are already updated for TV reception, that is great.
  • I wouldn't normally recommend buying new, but in your case it may make sense. Since you'll have to have much of the maintenance work done by others, buying an older rig, while cheaper initially, will require more preventive maintenance.
    Since you'll be living in your rig full time, bigger is better. Normally, a 45 ft diesel pusher that is 10 or more years old would be a good choice. But, in your case, maintenance costs might become prohibitive.
