DrewE
Dec 28, 2016Explorer III
A laminated wall is actually quite strong--certainly stronger than the layers are separately when not attached to each other. It's similar in concept to a hollow core door for a house. A hollow core door is entirely strong enough to use as a desk or table top, despite the skins being very thin plywood, since it's acting as a box beam rather than a sheet. (I speak from experience about the doors; in fact, I'm sitting at a desk composed of a door and two file cabinets that I've used for over a decade and a half.)
An RV wall, if the framework is solid, should be able to resist leaning against it and pressure that isn't completely localized quite well. It will not do so well against a maniac with a hammer or hatchet (though probably the windows and especially skylight would be easier to break through), nor a serious crash on the road, nor a tree falling on the unit. They will also lose a lot of strength if the materials or construction is compromised, say from rotting due to water intrusion.
Incidentally, while car frames are pretty strong, the skin of a car body these days is quite thin metal and it's not at all hard to dent or deform it with plain muscle power.
38,769 PostsLatest Activity: Mar 31, 2026
