dougrainer
Apr 02, 2018Nomad
The easiest way is to pull the water heater. You pull it out partially and when you have it out about 12 inches you can then access the water lines and such from the cavity in the closet area. Once those lines are disconnected(2) you pull the water heater. Fleetwood used to have a 120 cord plugged into a receptacle that made disconnecting the 120 cord easy at the rear. Doug
38,768 PostsLatest Activity: Nov 21, 2015
