- foothill999ExplorerThanks to all. I will check all those places today. I did notice in the kitchen that backs to shower there was a very small built in wood thing with 2 screw. I will take that off today too.
- klutchdustExplorer III noticed on my Cambria that by pulling out drawers you can access different wiring looms and water lines. I removed the plywood base to investigate my
on-going slide out problem in the bedroom and found the water pump and filter in there as well. Access panels are usually a great place to start. - Teacher_s_PetExplorerOur Phaeton tub/shower water supply access is behind the pull out pantry through a "fake" snap-in door. The furnace access hatch in the basement is the access to the shower drain proper and holding tank connections and vents. Our B+ has a valance panel along the tub side that can be opened by removing 4 screws.
- j-dExplorer IIOur older Jayco in signature has a little snap-in valve access cover in the pantry, and a drain access attached with screws in the shower base panel.
- ronfishermanModeratorNot sure about a Jayco. My access point is a small panel on front of shower tray. Same model from Gulf Stream put the access point on wall in living area of wall that shower shared.
- oldtrojan66ExplorerThis off the charts out there, but I have a Jayco fifth wheel with a kitchen slide. In the stationary cupboard next to the slide has a panel that gives access to at least supply plumbing, if not drain. Be someplace to start if it's there. Good luck.
38,769 PostsLatest Activity: Mar 31, 2026
