Sloop_Smitten
Sep 11, 2013Explorer
You need to put the potentiometer in parralel (not series) with the pressure sender. Tap into the wire that goes from the sender to the gauge with one wire to the potentiometer and the other to ground. You should then be able to adjust the overall resistance close to the needed range.
Total resistance = (R1 x R2)/(R1 + R2)
R1 = Sender resistance
R2 = Potentiometer resistance
38,769 PostsLatest Activity: Mar 31, 2026
