ChgoWinger
Mar 18, 2016Explorer
Clay L wrote:
See my edit above.
Thank you. for that
End play spec is 000 to .003". Mine has more end play than that.
The end cap is on there pretty well. I am going to have to use a torch or something to get it loose as it is not budging with a 18" wrench.
I'm not sure, Is the lock nut the larger nut or the smaller end cap with the square knub on the end?
here is the quote from the manual....
If the end play exceeds.003 inch in either assembly, adjust it to
within 0 to .003 inch.
Loosen large lock nut torque cap to 25'Ibs .and then loosen 1/16 turn and tighten lock nut
38,763 PostsLatest Activity: Dec 05, 2025
