wolfe10
Oct 20, 2013Explorer
Born To Travel wrote:
Never tighten a filter with a wrench. After installation, the rubber gasket expands and tightens it even further.. This is how professional mechanics do it.. If you use a wrench you will have a tough time removing it next time. And as for filling the filter, Just make shure everything you use is clean and free of dirt and you will be fine.. This is not brain surgery..
Actually many filters have instructions as to how tight past contact to take them. In many cases, it does require a filter wrench to reach the proper torque. I know all Caterpillar fuel and oil filters are so marked and even have numbers to help identify the proper torque/position.
38,766 PostsLatest Activity: Jan 10, 2026
