RV_4_2
Dec 27, 2014Explorer
How to charge a bank of 6V batteries
Well, I recently found out that the battery disconnect on my MH house batteries really does not fully disconnect the batteries. Kind of frustrating considering you would "think" that a battery disconnect would "disconnect" the batteries from whatever it is hooked up to.
I had my motorhome unplugged for a while and heard the CO2/smoke detector beeping yesterday like it has a low battery. Since it is hard wired, I decided to check on it and my house batteries were registering about 8 1/2 volts. I tried connecting my MH to shore power and letting the onboard charger work its magic but I got the indication that it would not charge due to the voltage being too low on the house batteries. SO, I need to charge them. I thought of looking at what people do to winterize their MHs but figured, I could get a better charging answer here.
I have a set of 4 6V house batteries for my motor home and am wondering if there is a simple way to charge all 4 at once.
Can i hook up a charger to the connections that feed the motor home and set the charger to 12V and let it slowly charge the batteries since the MH sees 12V? Or do I have to charge each battery individually.
I'm not opposed to individual charging but I am looking for an easier way taht wont take as long since I have to monitor the charger more closely.
Any help would be appreciated. Thanks
The longer term issue is making it a true disconnect.
