tenbear
May 01, 2013Explorer
Your tires are probably load range E, they have a maximum pressure of 80 psi, so when buying a compressor, make sure it will turn on above 80 psi when recycling. Even if your tires are load range D, many people replace their tires with load range E when it comes time. You also probably should buy an oil free compressor so it can be used for blowing out your water lines if you winterize where you live.
38,769 PostsLatest Activity: Mar 31, 2026
