lucytravel12
Apr 19, 2016Explorer
I ended up with a very simple solution, at least for those who don't use the store. I NEVER will use the cooktop; if it can't be cooked on the grill or in the microwave it won't be heated! I took off the grills and knobs, taped some 1/2" dense foam in the burners to make a level surface, and laid a thick microfiber cloth designed for use as a dish-draining cloth. The cloth is tucked under the edges of the stovetop, but can easily be removed and washed when it gets soiled. It works great. Thanks for all your good comments.
