bobndot
Feb 08, 2021Explorer III
happy-2 wrote:
I would take the new rv and try it before i bought it,,You mite try Air Bags. My 30 footer used to clear my driveway at 1 in .but with Airbags i now have 6 in more.i can keep the tow bar on and its off the ground at 18 in.
I did the same using AirLift bags and they only raised my already sitting level 24’ C 1/2”.
It was explained to me by Two AB companies that AB’s are designed to raise a sagging vehicle back up to level .
Before you install a set of AB’s to try to solve a scrapping clearance issue , i would make a few calls. I tried the wireless onboard compressor and it was leaking from day one. I got a full refund on parts and installation a few weeks later. Total was $1700. Wireless compressor model is expensive.
A truck spring shop can install spacers and that will raise it to what you need. The overall height of the rv as well. Its possible that you might feel crosswinds a little more.
