BigRabbitMan
May 29, 2016Explorer
Use the screens referenced above that are made for the job as they HAVE to be metal or they will burn/melt on the exhaust port. Bumble bees nest in the ground so I think you have wasps. Honey bees need a larger space so probably not them either. If wasps and they have built a nest inside, you will need to remove it after killing the wasps as the nest will restrict airflow and the heater will not work due to overheating.
38,778 PostsLatest Activity: Jun 10, 2026
